1996 Chevy Lumina surging
JAMES 69
Engine problem
1996 Chevy Lumina V8 Front Wheel Drive 168k miles
car runs great. intermitten surge after warmed up sometimes worse than others, less over 60mph. kick into passing gear usually stops it. not noticeable while on cruise control. quite often at low speed. fuel pressure checked,filter replaced, injectors purged, maf sensor,maybe? new plugs and wires.
Feb 13, 2008 at 12:45 PM
MASTERTECHTIM
  • 4,750 POSTS
tune up? first thing to check is the coil towers, where the plug wires plug on to coil, are there any burnt spots? this is where i would look first.
Feb 13, 2008 at 12:49 PM
