1996 Chevy Lumina start-doesent start
GLEN608
  • 1996 CHEVROLET LUMINA
Engine Performance problem
1996 Chevy Lumina 6 cyl Two Wheel Drive Automatic 20000+ miles
My lumina is driving me to drink! For the past 6 mo. Its faled to start try aprox 1 hr later starts up and runs like new. It does this intermitenly never know when rain shine whatever. My wife just went to use it would not go I took her to work came back started up run fine. Its hard to fix something that works then doesent. Need help! Glen
Monday, May 10th, 2010 AT 10:59 AM
INTERNETMECHANIC
  • 700 POSTS
When the problem occurs, do some basic testing, if you haven't already. Have a helper crank it, while you visually check for spark at the plugs. If that checks ok, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage if you don't have one. An intermittent rpm signal can drive you crazy. I wouldn't replace anything without trying to do some testing.
Usually when you donate, one of the moderators will talk to you.
Monday, May 10th, 2010 AT 12:21 PM
