1996 Chevy Lumina Sputters and dies.
164,000 MILES • 6 CYL • FWD • AUTOMATIC
LISHIE
I've been having trouble keeping my car running lately. When I start it, it tends to sputter for a few seconds, then die. When it stays running, I have to sit and wait for a few minutes before I can drive away, or it will die. I was told to replace the mass airflow sensor, which I did, but it did not help. I don't know if it's coincidence or not, but it seems to run worse on days like today when it's a little nicer outside (around 50 degrees). Help me please :)
Feb 8, 2009 at 6:35 AM
  • 110,246 POSTS
Hi:
Is the check engine light on?
Feb 10, 2009 at 6:28 AM
LISHIE
No, it isn't.
Feb 10, 2009 at 7:23 AM
  • 110,246 POSTS
I recommend checking fuel pump pressure. Many parts stores will lend or rent the gauge. If you need to know how to do it, check out this web site:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find.
Feb 10, 2009 at 8:28 AM
