1996 Chevy Lumina replacing thermostat
SDUFFY
  • 1996 CHEVROLET LUMINA
Heater problem
1996 Chevy Lumina V6 Two Wheel Drive Automatic 112000 miles
how to replace thermostat
Tuesday, December 11th, 2007 AT 1:48 PM
MERLIN2021
  • 17,250 POSTS
Let the engine cool off, then drain it down about a gallon, there is a draincock on the bottom of the radiator, then follow the upper radiator hose to the engine, there you will find the thermostat at the end of the hose, unbolt the two bolts. Leave the hose attached to the housing. Scrape old gasket from both mating surfaces, install new thermostat, spring towards the engine. Install the gasket, snug the housing bolts! Not to tight and bring the housing down evenly. Refill the coolant and that's it!
Friday, June 21st, 2019 AT 3:03 PM
