1996 Chevy Lumina Radiator Cooling Fan
40,484 MILES • 6 CYL • FWD • AUTOMATIC
PUN_SMITH
My 1996 Cherolet lumina Sedan temperature gauge began to climb more than usual, when i checked out the problem, i found that the radiator fan was not coming on. The one for the A/C works just fine and when I switch the fuses from one to the other, the A/C Fan still works properly. I have checked out all the fuses tha could possibly be linked that i know of, what route should i take next?? I don't want to go out and buy a radiator fan motor unless i know for sure that it is the problem.
Thanks
Dec 12, 2007 at 9:02 PM
KNOBBY
  • 37 POSTS
the ecm sends a ground to the fan relay when its hot the relay sends ether 12 volts or a ground to the fan you need a test light there are 2 wires going into the fan motor check for 12 volts and ground
Apr 6, 2021 at 12:55 PM
