1996 Chevy Lumina no fuel pressure
180,000 MILES • 6 CYL • FWD • AUTOMATIC
TEBIANNI
I installed a new fuel pump in my 96 chev lumina. When you turn the key on you can hear the pump run for a few seconds, but there is no pressure at the fuel rail. The tank is half full and I have hooked it up to a computer. When I purge the injectors it says no fuel pressure.
Jan 2, 2009 at 6:29 AM
  • 75,988 POSTS
You need to recheck the fuel pump installation -you sure you hook everything up correctly. also check the fuel pressure regulator-could be leaking
Jan 2, 2009 at 6:53 AM
TEBIANNI
The new wire harness that came with the pump,had the positive and neg. turned around making the pump run backwards. Check the harness, like I should have done. This will save you from having to remove the tank twice.
Jan 5, 2009 at 6:08 AM
