1996 Chevy Lumina No dash lights..
BRYANS HOTROD SHOP
Electrical problem
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
No dash lights coming on. Think it is the headlight switch cause it has done this before and played with the switch and they came on.
Jul 8, 2010 at 3:40 PM
INTERNETMECHANIC
  • 700 POSTS
You may be correct about the headlamp switch? In the wiring diagram, gray wire is voltage to the instrument lamps, black wire is ground.
https://images.2carpros.com/forum/automotive_pictures/512072_lumina_headlamp_switch_2.jpg
Jul 9, 2010 at 4:01 AM
