Engine Performance problem
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
1996 Lumina, every couple of months or so, the car will not idle, this morning the car would not idle when cold, so I drove it and after a few minutes it was ok, the idle was good...
When at a stoplight, I do notice the tachometer will
jump as the engine appears to have an occasional miss.
Last year I had plugs and wires installed.
The fuel filter has not been changed for about 8 years, the car just turned 100K...
Also, just discovered that plastic radiator is leaking, the job looks to be a bit much for me and I will have to bring it to a shop...What happened to Steel radiators?
thanks
Nick
thanks
Nick
Apr 8, 2008 at 12:44 PM
