1996 Chevy Lumina Interior Lights wont shut off/ Brake ligh
172,900 MILES • 6 CYL • 2WD • AUTOMATIC
JMIKEK90
i got out of my car and the interior dome light and rear-view mirror lights would not go off. i ended up pulling the fuse so i didnt kill the battery. also when i hit the brake my rear window brake light comes on but not the tail brake lights.
Aug 12, 2009 at 6:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
for brake lamps, first inspect bulbs. if OK, suspect faulty brake lamp switch.
for interior lamps, suspect sticking / faulty door ajar switch. spray WD40 in all door latches to see if this helps the issue.
Aug 12, 2009 at 6:04 PM
