I had a thermostat put on this car 8-4-08 and then the water pump was leaking so I had it replaced9-27-08. Yesterday I went outside and saw something leaking and took it to the shop and the mechanic said it was the intake gasket leaking. Do you think that this is normal wear and tear or something else. Should the system have been pressurized after the water pump was put on?
Oct 6, 2008 at 5:29 AM
