1996 Chevy Lumina Ignition switch
EDDIEN
1996 Chevy Lumina
Any diagrams available to show procedure to change ign switch on this car?
Nov 5, 2009 at 4:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
are you replacing the actual switch or just the lock cylinder (where key inserts)
Nov 5, 2009 at 11:57 AM
EDDIEN
ignition switch. Lock cylinder ok.
Nov 5, 2009 at 8:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1153.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_334.jpg
Nov 6, 2009 at 6:59 AM
JADEANDICE85
ok. I am having the same problem but mine is a bit difficult to fix, as the bolts that hold the steering column are stripped. How can I fix this? The problem started with the Starter, I had someone replace the starter, the battery, and then the ignition switch. NONE of these worked. I have even had the key re programmed because someone said the chip was bad, then paid over $200 for a new key that still wont work. I was told by the second "mechanic" that came out that my computer was fried.......3rd mechanic said that was total BS, that it is a simple problem of improper placement of the ignition switch, that now I don't have the money to get fixed.........anyone out in the cybersphere know anything more or anything on this issue??
Apr 24, 2016 at 3:26 AM
