1996 Chevy Lumina help Lumina idling issue
1996 CHEVROLET LUMINA
108,000 MILES • 6 CYL • AWD • AUTOMATIC
OREOME32278
Thanks in advance for your help :-)
I have a 96 Lumina 3.1 v6 engine. 2 years ago i had new head gaskets and new fuel regulator/fuel pump replaced on car.
Everything has been fine, however, after going about 200 mile trip the next time I got in my car to pull out of my driveway it did a little "bucking motion" in reverse and since my RPMs have been high.
When I start the car we are @ 1000rpm and when driving I'm shifting at the high end 3000rpm when my foot is on gas and stays around 2300rpm, when my foot is off it seems to settle around the 1500rpm where it normally has been.
I was wondering if anyone had any information that could help me figure this out!! No check engine light.. my coolant level is fine and so is the oil!
Thanks again.!
Crystal
Oct 24, 2009 at 5:55 AM
SERVICE WRITER
  • 9,123 POSTS
IT sounds like you have a vacuum leak.
IF you open the hood with the motor running, do you hear any hissing sound?
Oct 24, 2009 at 9:02 AM
OREOME32278
I just started the car and yes.. there sounds like there is a hissing sound..
i looked at the hoses i could see and they all looked tight and not ripped?? it sounded like it was coming from the back of the engine... any thoughts???
Oct 24, 2009 at 4:30 PM
SERVICE WRITER
  • 9,123 POSTS
Not sure yet, but you can take some carb cleaner and spray the area that has the hiss. If the idle changes because it is now richer, then you can narrow down the source.
Oct 24, 2009 at 4:57 PM
