1996 Chevy Lumina gasket problem
106,000 MILES • 6 CYL • FWD • AUTOMATIC
TETSUYABOSS
My 1996 lumina started knockin 2 days ago.
There is coolant leakage into engine oil which causes oil to be milky. I searched on the net and found out that intake manifold gasket failure is common problem for Lumina. I probably drove 20 miles with the coolant leaked into oil. Can I still get away with fixing only the gasket or do I need something more to it like rebuilding the engine?
Aug 26, 2008 at 8:24 AM
  • 31,937 POSTS
Hi there,
you should be OK, replace the faulty gasket and flush the engine oil and change the filter, you may have to do this twice, but i feel that you should not have done any damage.but don't wait get it done now.
Mark (mhpautos)
Aug 26, 2008 at 10:32 AM
