1996 Chevy Lumina fule pump
TINNMAN47
  • 1996 CHEVROLET LUMINA
Engine Mechanical problem
1996 Chevy Lumina 6 cyl Two Wheel Drive Automatic
how do I change fule pump?
can I do it by going under back seat or do I have to drop the gas tank
and if so how do I drop the tank?
Thursday, September 25th, 2008 AT 8:29 PM
EWOOLSEY
  • 8 POSTS
If you get out the backseat you should see a door that comes off. If not to drop the tank you will need to unbolt the tank straps that are holding the tank in place. Should be 4 bolts on the straps.
Saturday, November 22nd, 2008 AT 6:42 PM
