1996 Chevy Lumina FUEL PUMP/PCM COMPUTER
102,000 MILES • 6 CYL • FWD • AUTOMATIC
GLADSAG09
I RECENTLY HAD SOME WORK DONE ON MY LUMINA. THE MECHANIC SAID THE FUEL PUMP WENT OUT. HE WAS IN THE PROCESS OF WORKING ON THE CAR AND SOME HOW MANAGED TO CONTINOUSLY BURN THE RELAY. THIS CAUSED AN ELECTRICAL PROBLEM AND BURNED THE PCM MODGULE . THEM HE INFORMED ME THAT THE PCM COMPUTER WOULD NEED TO BE REPLACED. OUNCE THAT WAS DONE I GOT MY CAR BACK. HE INFORMED ME TO GET A OIL CHECK AND I DID. AND AFTER THAT IT RAN GREAT.... BUT JUST FOR A DAY!!!! IT BROKE DOWN AGAIN AND NOW IM CONFUSED AS TO WHY?! IS IT THE PCM? IS IT FUEL PUMP? OR SOMETHING ELSE ALL TOGETHER?
Aug 21, 2009 at 1:35 AM
JDL
  • 16,098 POSTS
Hello, all I can do is talk about basic testing. Have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Have you talked to the person that did the work?
Aug 21, 2009 at 2:02 AM
