1996 Chevy Lumina fuel filter or fuel pump?
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
INHALE2PUFFS
For the last couple months my car will not start on the first try. Now it takes 4 times before it will start. After it starts it runs fine. Does this sound like a fuel filter problem? I can't get the fuel filter off as the nut is rusted on, so I have to bring the car to a garage to have it lifted so the filter can be removed. My problem is, of course, I cannot afford to have both the fuel filter and fuel pump replaced. I want to start with the cheapest(fuel filter) but if I spend the $80 for that and the car still doesn't start--then I'm out $80 for nothing.
What do you think?
Thank you for your time!
Diane
May 2, 2008 at 1:16 AM
  • 75,988 POSTS
Check the fuel pressure this will tell you if its the filter or the fuel pump
May 2, 2008 at 2:25 AM
  • 75,988 POSTS
I need the fuel pressure before I can proceed.
May 2, 2008 at 3:21 AM
INHALE2PUFFS
Don't know what the pressure is. The mechanic only told me that "it was fine" and "let's start by replacing the fuel filter and go from there". I need to get this fixed, so what should I know before I take the car back? (just so I know they're not trying to screw me). What should the pressure be if the fuel pump is good?
May 2, 2008 at 3:42 AM
  • 75,988 POSTS
Fuel pressure should be 41-47psi
May 2, 2008 at 8:00 AM
