I just had a rebuilt transmission put in last week and now the engine is knocking very loudly.
Mar 30, 2009 at 5:06 AM
✓Experienced Mechanic
Check the oil pressure to rule out the oil and engine bearings. Is the oil light coming On?
Mar 30, 2009 at 7:32 AM
ALGEORGE
MEMBER
NO, I got a new transmission put in last week and two days later the engine is knocking.
Mar 30, 2009 at 8:19 AM
ALGEORGE
MEMBER
Do you think it would help to get a tune up?
Mar 30, 2009 at 8:22 AM
A tune-up is not gonna help -You need to locate where that knocking is coming from then comeback and tell.
Mar 30, 2009 at 11:16 AM
ALGEORGE
MEMBER
There was a hose loose that connects to the engine and one that has a crack in it. I think the noise is actually air pressure. I am wondering if something happened when the transmission was put in.
Mar 30, 2009 at 11:34 AM
There was a hose loose that connects to the engine and one that has a crack in it. Where does this hoses connect to-I need more information before I can help.
Mar 30, 2009 at 11:38 AM
ALGEORGE
MEMBER
I don't know anything about cars so I have to say there is a big hose right at the front and a skinny hose underneath.
Mar 31, 2009 at 12:43 AM
Can you give a clear picture of it
Mar 31, 2009 at 7:29 AM
