1996 Chevy Lumina dash lights,clock,&washer solvent do
1996 CHEVROLET LUMINA
98,000 MILES • 6 CYL • FWD • AUTOMATIC
MLASCOLA
Recently a new battery was installed by a friend. Subsequently when the head light switch is turned on the dash lights dont turn on and the clock on the radio turns off. Also the washer solvent pump will not work. I checked all the fuses and none are blown
Oct 9, 2008 at 10:35 AM
  • 110,240 POSTS
Hi:
Check and make sure the ground cables going to the engine block and body are clean, secure, and tight.
Oct 14, 2008 at 3:31 AM
