The brake light in the back window does come on when I brake, but the two brake lights located inside the tail lights do NOT come on when I brake. Someone suggested the ground wire, but I am not sure if they are referring to the wire that plugs into the tail light connector or if there is a ground wire at the pedal. Could there be something else that would cause this? I am confused because the brake light in the rear window does work but the tail light brake light does not.
Also, the tail light running lights work and so do the rear flashers. It is only the brake lights that do not work.
Thank you for your help.
Dennis
Dennis
Nov 26, 2008 at 12:22 AM
