1996 Chevy Lumina anti-theft system
156,000 MILES • 6 CYL • FWD • MANUAL
CBASSWOOD
what can I do to reset the anti-theft system, I replaced the engine, along with the steering column, now the starter will not crank over when I attempt to start it with the key, I believe it has to be the anti-theft feature causing the problem,
Jul 15, 2009 at 3:54 AM
  • 110,248 POSTS
TO the best of my knowledge, there is a sensor in the steering column that determines if the correct key is being used then sends a signal to the computer. If they don't recognize each other, it won't work. A dealer is the only one to the best of my knowledge that has the proper test equipment to check and determine if that is the problem.
Jul 26, 2009 at 3:33 PM
