1996 Chevy Lumina 96 LUMINA, please help
148,542 MILES • 6 CYL • FWD • AUTOMATIC
THOMASRAUSCH19
i go to start the car, put key in, and turn to on position, the volts light doesn't show, and can hear a clicking noise coming from the box with relay switches. and after about 3 minutes the noise stops the fuel pump turns on and will start. thought it was the fuel pump relay, replaced that, seemed to work, but then 2 weeks later, same problem. :(
Nov 20, 2009 at 12:58 PM
  • 110,248 POSTS
When this happens, does the security light stay on or flash?
Dec 5, 2009 at 1:12 PM
