1996 Chevy Lumina
TWO EARS
Engine Mechanical problem
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
my friends 96 lumina starts but you have to turn the key on and off a couple times before it starts then runs fine what is the fuel pressure suposed to be could it be the regulater and you cant hear the fuel pump runnig but it works cause he drives it every day
Sep 24, 2010 at 12:19 PM
NICKHEADZ34
  • 62 POSTS
does it also run rough when it first drives in the day? im having a problem right now that sort of sounds like his but im looking into it right now. im hearing it may be an idle control valve which i happen to haave a spare of. im going to play with it a bit tomorrow.
Oct 2, 2010 at 1:41 PM
TWO EARS
problem fixed it was the fuel pump
Oct 3, 2010 at 5:44 AM
NICKHEADZ34
  • 62 POSTS
damn. ive recently had that done.
Oct 3, 2010 at 7:12 AM
