1996 Chevy Lumina
BRENTANMEL
Electrical problem
1996 Chevy Lumina 6 cyl Front Wheel Drive
I just bought my daughter a lumina and when it is first started and cold the interior dash and radio lights will not illuminate. Also the rear defrost wont come on. Eventually they both do. I just replaced the alternator and have check voltage and grounds.
Jan 13, 2010 at 3:45 AM
RACEFAN966
  • 5,029 POSTS
Have you checked the headlight switch? It seems that it supplies power to both the dash and radio. The rear window defogger may be the relay for it.
Jan 13, 2010 at 1:41 PM
BRENTANMEL
I think it is the switch but I am having a hard time getting it out.Thanks
Jan 13, 2010 at 11:20 PM
RACEFAN966
  • 5,029 POSTS
Best I can tell it looks like you remove the bezal around the instrument cluster and then that will gain you access to the screws to remove the switch. If need be include pics and I will look at them and give you my thoughts.
Jan 14, 2010 at 2:38 AM
BRENTANMEL
Thanks I will try tonight after work. I think that panel just snaps out but I did not want to ruin it.
Jan 14, 2010 at 3:46 AM
RACEFAN966
  • 5,029 POSTS
There may be a couple of screws but other then that yes it pops out just do it carefully and you will be fine. Let me know how it goes. If you have any questions just ask.
Jan 15, 2010 at 1:56 AM
