HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine
Intake Manifold
Gasket
Replace/Remove
SPONSORED LINKS
1996 Chevy Lumina
ROBINC73
MEMBER
1996 CHEVROLET LUMINA
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
the intake manifold gasket needs to be replaced on my car. Is this something I can fix myself? If so how do I do it? I need a little guidance.
Monday, July 6th, 2009 AT 1:25 PM
BUDDYCRAIGG
MECHANIC
Spend 15 bucks on a book from a parts store.
Spend the 70 bucks for the "upgraded" kit from a GM dealer.
The rest is a cake walk.
And when you refilll the coolant, use the good old fashioned green stuff.
SPONSORED LINKS
Monday, July 6th, 2009 AT 10:00 PM
Please
login
or
register
to post a reply.
Related Intake Manifold Gasket Replace/Remove Content
1996 Chevy Lumina Bad Intake Gasket
Can A Bad Intake Gasket Cause Egr Code/problems? I Have Replaced Egr Valve (with Another Used One That I Cleaned From Junkyard), Have...
Asked by
Chrystal919
1 ANSWER
1996
CHEVROLET LUMINA
1994 Chevy Lumina Intake Plenum Gasket And Wire...
I Have An Intake Leak In My 94 Chevy Lumina Z34. 3.4 Dohc Automatic And Im Going To Attempt To Correct That By Replacing The Spark Plug...
Asked by
nickheadz34
1994
CHEVROLET LUMINA
1995 Chevy Lumina
My Car Began Running Rough Last Week. No Cel. It Felt As Though A Plug Wire Was Missing. I Did The Head Gaskets And Lower Intake Gaskets...
Asked by
Ian McDiarmid
1995
CHEVROLET LUMINA
1992 Chevy Lumina
I Have A '92 Chevy Lumina With 195,000 Miles On It. After Driving Car You Could Smell Anti-freeze.I Replaced The Lower Intake Manifold...
Asked by
mikelink
1992
CHEVROLET LUMINA
1997 Chevrolet Lumina Gasoline Mixing With My Oil
This Whole Problem Started After I Had Payed A Mechanic That Graduated With Me But In A Auto Mechanics Class That Required Them To Get Their...
Asked by
zombiejr4
1997
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
Vacuum Leak Test and Repair
Service Throttle Body Toyota Highlander V6
Throttle Body Service Chevrolet
Online car repair manuals
