1996 Chevy Lumina
1996 CHEVROLET LUMINA
OMARROSAS
1996 Chevy Lumina 6 cyl
timing belt what does it do
Jan 23, 2009 at 1:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The timing belt is a toothed rubber-like belt that keeps the crankshaft, auxilary shaft and camshaft(s) in time with one another. It is critical if your engine is going to run, as an engine out of synchronization will lack compression and the ignition will not fire on time.
Thanks for using 2CarPros.com!
Jan 23, 2009 at 1:33 PM
