1995 Chevy Lumina turn signal
236,102 MILES • 6 CYL • FWD • AUTOMATIC
GARLAND02
okay my question is
when you turn on the headlights the right turn signal light stays on but it wont blink at all. also when the headlights are off the turn signal works just fine. I just replaced the turn signal swith but that didn't do the job so what would cause that to happen ?
Feb 11, 2008 at 12:09 PM
BMRFIXIT
  • 19,053 POSTS
check the bulbs and bulb socket
make sure you have the correct bulbs in the right place
check ground wire at the sockets
Feb 11, 2008 at 12:49 PM
