1995 Chevy Lumina timing
RMOE
Engine Mechanical problem
1995 Chevy Lumina 6 cyl Two Wheel Drive Automatic
I would like to know how to time a 1995 Chev Lumina 3.4 double overhead cam
The Chev dealership closest to us does not know!
Aug 17, 2010 at 6:32 AM
WRENCHTECH
  • 20,760 POSTS
Of course they know, they just don't plan on explaining it to you.
This is probably one of the most complicated belts to set up because the cams are timed 180 degrees out of each other and it also requires a set of special tools designed to hold the cams in the correct position. It has no timing marks. The setup tools alone cost over $200 so you may want to think twice about tackling this one.
Aug 17, 2010 at 6:48 AM
