I have a 1995 Chevy Lumina APV, it has 176,000 miles on it. I had an accident and ran a steel pole and damaged the right front side of my van. (I hit the pole and slidely crack the fender but also my tire got part of the pole and pushed it back where it is touching the bottom side of the fender) drove it home. I went to the junk yard and got a lower control arm and replace it. I also replaced the struts.
Now, I am hearing a thumping noise coming from the front right where the damage is. And also the left side I am beginning to hear the same thing. My guess are the CV Joint is going out, struts need replaced, or some other thing. Oh! I did replace the lower ball joint about a year ago. What could be the problem? Any help will do. Thanks
Jun 5, 2008 at 3:45 AM
