1995 Chevy Lumina spongy brake pedal
OPIE747B
Brakes problem
1995 Chevy Lumina 6 cyl Front Wheel Drive Automatic
bleed brakes, pads look good, no fluid leaks,pedal still spongy. Is there a sequence to bleeding lines? Master cylinder first then brake lines ? Or is ther other things I should check
Jul 14, 2008 at 3:00 PM
  • 31,937 POSTS
Hi there,
you may have a faulty master cylinder, i would be starting there.
mark (mhpautos)
Jul 14, 2008 at 6:52 PM
