1995 Chevy Lumina spongy brake
OPIE747B
Brakes problem
1995 Chevy Lumina 6 cyl Two Wheel Drive Automatic
brake pedal is spongy when driving bleed brakes problem still exists
Jul 14, 2008 at 9:39 AM
  • 75,988 POSTS
Pads and Shoes could be worned-wheel cylinders leaking or try bleeding the master cylinder then the wheels-
Jul 14, 2008 at 10:04 AM
MERLIN2021
  • 17,250 POSTS
Spongy? Or excessive travel? Brakesmay need adjustment or replacement. Especially the rears. Have you checked the fluid in the master? Do't let it run dry, add only DOT3 brake fluid.
Jul 14, 2008 at 10:06 AM
