1995 Chevy Lumina Oil leak
102,000 MILES • 6 CYL • FWD • AUTOMATIC
BILL1806
I have a 3.1 liter engine that appears to be leaking oil from the block, somewhere under the throttle body. I lose about a quart a month. Where could this be coming from? It's not the valve cover gasket.
May 8, 2009 at 2:56 PM
LEGITIMATE007
  • 5,121 POSTS
on 3.1's there is a ,what is called a dummy shaft, it is closed up hole where a distributer would go if you where to put one on. and when the o ring in there goes bad, it will begin leaking oil, I have a 3.1 corisica with the same problem. Its quite a job just to get in there and change the o ring too, because I did it on another corsica that I had, but I refuse to do this one,not a good idea but hey
May 8, 2009 at 3:01 PM
