1995 Chevy Lumina No Tailights or dashlights
1995 CHEVROLET LUMINA
12,500 MILES • 6 CYL • FWD • AUTOMATIC
JEFFREYWEYRICK
My sons lumina has no tailights or dashlights,he has brake lights+turn signals+headlights,all fuses looked good,we replaced headlight switch also.All wires look ok,,is there an in line fuse someplace I missed? All fuses under hood appear to be ok also,has me baffled. Thanks, Jeff What else can I check?
Jan 15, 2010 at 6:19 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Check the park lamps fuse-- 25 amp, underhood fuse box. Use a testlite on the fuse circuit, it should be hot all the time. That circuit is an orange wire at the headlamp switch. When the switch is activated, the brown wire carries voltage for the tail lamps. You could also check for voltage and ground at the tail lamps.
Jan 15, 2010 at 6:41 AM
