1995 Chevy Lumina Heater control
135,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGHACK76
My cars heater/ac climate control is stuck in "defrost/floor." I have replaced the heater control module with 5 different ones from a local junkyard, but none of them worked. It seems odd that none of them would work, but stranger things have happened! Is there another possible problem I can try to fix?
Jan 19, 2010 at 10:01 AM
SCOTTY DEE
  • 592 POSTS
Fix the blend door problem. It's under the glove box in the lower part of evaporator case.
Jan 27, 2010 at 7:54 AM
