1995 Chevy Lumina Heater
1995 CHEVROLET LUMINA
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJOK72
My heater fan does not work switch is good relay is good I dont no the place the fan resistor is located do you?
Nov 14, 2008 at 3:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Below are instructions for removal/installation of blower motor. The resistor will be located next to the blower motor.
REMOVAL:
Disconnect the negative battery cable.
Remove the right side sound insulator under the instrument panel.
Unfasten the convenience center rear screws. Loosen the front screw and slide the convenience center out.
Grasp the carpet at the top side of the cowl and pull forward.
Detach the blower motor electrical connection.
Disconnect the harness from the clip.
Unfasten the blower motor mounting screws, then remove the blower motor from the vehicle.
INSTALLATION:
Position the blower motor and secure using the retaining screws.
Connect the harness to the clip.
Attach the blower motor electrical connector.
Reposition the carpet at the cowl.
Place the convenience center into position. Install the front and rear screws.
Install the right side lower insulator panel.
Connect the negative battery cable.
Nov 14, 2008 at 3:54 PM
JJOK72
The Blower Motor Resistor is located under the hood on the passenger side next to the blower motor in the passenger side rear of the engine just to the left of the blower on the fire wall.
Nov 18, 2008 at 12:04 PM
