1995 Chevy Lumina Hard shift from P to R
173,000 MILES • 6 CYL • FWD • AUTOMATIC
BILL GIFFORD
This car is an on the steering shaft gear selector. When going from Park to Reverse it's real hard to shift it. If I pull the shift quickly past R and then back it is normal shift stiffness.
Mar 21, 2010 at 9:58 AM
LEGITIMATE007
  • 5,121 POSTS
I suspect the linkage may be a little bound up. a little pb blaster or wd 40 and you should be ok
Mar 22, 2010 at 2:50 PM
