1995 Chevy Lumina gas fumes
1995 CHEVROLET LUMINA
BEWILDERED1
Smells problem
1995 Chevy Lumina 6 cyl All Wheel Drive Automatic 115.00 miles
every time that i start my car i get a smell of gas coming from either the engine or somewhere else. it can also be detected coming from my vents for heat.
Mar 22, 2009 at 7:21 PM
JDL
  • 16,098 POSTS
Hello, I'd check the fuel lines under the hood, see if you can find a leak anywhere. You might also check the vacumm line at the pressure regulator.
Mar 23, 2009 at 11:06 AM
