1995 Chevy Lumina Fuel tank strap replacement
BRH1970
1995 Chevy Lumina
Is it necessary to drop the fuel tank when replacing the fuel tank straps?
Nov 22, 2009 at 8:17 AM
  • 110,248 POSTS
You should be able to replace them without removing the tank. Do one at a time, and support the tank so it doesn't move when you remove the strap.
Let me know if you have other questions. Also, spray down the retaining bolts with a penetrating oil several times before trying to remove them. Chances are they are rusted and you don't want them to break.
Dec 5, 2009 at 1:05 PM
