1995 Chevy Lumina fuel pump relay locater
1995 CHEVROLET LUMINA
ARUBAN INDIAN
Electrical problem
1995 Chevy Lumina V6 Front Wheel Drive Automatic 120000 miles
My pump keep on running it dont stop some times I had change the fuel filter nothing more if it is the relay where sould i find that i look all over the car
Dec 6, 2007 at 10:06 AM
VIDEOTP
I have a 91 Lumina and the fuel relay and fuse for it are in the engine compartment between the battery and the strut upper mount on the drivers side, (back of the engine) against the inner fender wall. Look for a 2X2" Black box it may say fuel pump relay on the top. Pinch the two latches on each side to remove the cover. You can pull the relay out by rocking while pulling upwards. It is normal for the relay to pull in and run the pump for the first 2 seconds that you turn the key on... and run continuously after you start the car.
John
Jan 14, 2008 at 2:05 PM
