1995 Chevy Lumina engine want turn over no fire to the star
OSCAR DANTZLER
  • 1995 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 180,030 MILES
All lights works, horn blow loud, new battery, with the ignition switch turn on all dash red gauges lights and security lights are on, but engine want say anything. I had stater check it was ok. Engine want turn over no fire to the starter selonoid small wire. With ignition switch turn on and I jump the starter with a screw driver it will turn over and crank, but it die immediately. I have also checked all fuses to see if they were blown and none were blown.
Saturday, June 12th, 2010 AT 2:32 PM
Hi oscar dantzler, Welcome to 2carpros and TY for the donation
No power at the starter solenoid small terminal purple possible causes here could be the park and neutral switch and ignition switch
it will turn over and crank, but it die immediately. This could be the ignition switch, open ignition circuit-could also be the idle air control valve the needs to relearn itself bcuz you disconnect the battery and it loses its programmed memories
Sunday, June 13th, 2010 AT 5:31 AM
