Engine heats to operating temperature, then will overheat sometimes. When the engine overheats the cooling fans do not come on until the engine reaches about 260 degrees. Also they do not come on when the A/C is turned on. Checked both relays for the cooling fan and the fan is getting good power and ground. Fan will run when hardwired to battery but won't kick on at 220 degrees when its supposed to
Dec 18, 2009 at 3:39 AM
