1995 Chevy Lumina check engine
117,000 MILES • 6 CYL • FWD • AUTOMATIC
LICHTENB
on my 3.1 engine the check engine light comes on after decellerating from 55 mph. i changed the egr valve cleaned the port on the intake replaced plugs wires air cleaner checked vacuum lines. The NO is high at 1200 and should be 800.
May 6, 2009 at 7:08 AM
  • 110,248 POSTS
Have you had the computer scanned for codes?
May 8, 2009 at 5:16 AM
