1995 Chevy Lumina carb backfire
199,890 MILES • 6 CYL • 2WD • AUTOMATIC
JD53566
my engine is a 3.1 and start to back fire after it warms up thru carb. and while in gear driving , when i step on the gas it backfires thru carb. i did tune up about 12000 miles ago.
Oct 26, 2010 at 10:04 AM
  • 75,988 POSTS
Check the fuel pressure, ignition timing,wrong heat range on plugs, excessive carbons in the cylinders and lean or rich fuel mixture
Oct 26, 2010 at 10:28 AM
