1995 Chevy Lumina alternator is being grounded out
1995 CHEVROLET LUMINA
SARA27
  • 7 POSTS
Electrical problem
1995 Chevy Lumina 6 cyl Two Wheel Drive Automatic
changed alternator but car is still running off of battery. changed battery, all fuses underhood, alternator belt, tensioner, tested the red wire to alternator is getting right volts ...But Alternator Is being grounded out some how. I'm not sure what else to check?
Jun 24, 2009 at 12:53 AM
DOCFIXIT
  • 18,828 POSTS
Check two fuses one in engine compartment box the BMIS 15A and in box in cab fuse # 39.
Jun 24, 2009 at 7:43 AM
SARA27
  • 7 POSTS
Checked fuses all were in good condition but changed anyway and still the aternator is being grounded out.
Jun 29, 2009 at 3:03 AM
DOCFIXIT
  • 18,828 POSTS
Use a volt meter battery voltage engine off? Engine running voltage on B+ large red wire and vlotage on small red wire at terminal connector? Is charge light on with key on before you start and does it go out?
Jun 29, 2009 at 3:17 AM
SARA27
  • 7 POSTS
the auto zoner wasnt helpful with the answers to ur questions..he said that the battery was very weak when engine was off and thought it wouldnt crank but it did. stated that alternator isnt charging at all..there was no charging light on when key was on before starting car.
Jun 29, 2009 at 4:23 AM
