1995 Chevy Lumina Altenator wont charge battery
1995 CHEVROLET LUMINA
SARA27
  • 7 POSTS
1995 Chevy Lumina 6 cyl Two Wheel Drive Automatic
my car wouldnt start so had to jump off battery. 2 days later went dead again, so had battery charged. drove 85 miles and car went dead in middle of road. bought new battery. went dead again..changed altenator...when u start car u can see that the power kicks up and down every 2 minutes...cd player wont work..head lights flicker...changed altenator second time but car still runs off of battery power...What's wrong with my car??????
Jun 8, 2009 at 3:58 AM
JDL
  • 16,098 POSTS
Hello, use a digital multimeter, do some tests. With the engine turned off, take a reading across the battery posts. Start the engine take another reading across the battery posts, the second reading should be higher, if it isn't, take a reading at the alternator bat terminal, if that reading is higher, there maybe an open circuit between the alternator and battery. You can take a reading at the alternator bat terminal, everything turned off, it should show battery voltage?
Does the charge lite on the dash, work ok? Is the alternator new?
Jun 8, 2009 at 4:16 AM
SARA27
  • 7 POSTS
were do i go to get testing?? or how do i test it myself? the battery light works came on 1 time before but not now...yes altenator was bought at auto zone. i took the first one back because i thought something was wrong with it...but second 1 does the same thing..
Jun 8, 2009 at 9:34 AM
