1995 Chevy Lumina air compressor removal
186,000 MILES • 6 CYL • FWD • AUTOMATIC
KEPLER2
wondering how many ways there are to remove the air compressor. sorry for being brief.
Dec 30, 2007 at 8:30 AM
  • 31,937 POSTS
To remove an a?c compressor, first the system has to be evacuated by mean of a refrigerant pump, do not under any circumstances undo or cut A/C hose. this is extremly dangerous. When system is empty, remove belt, and compressor will unbolt from it's cradle or mounts. If the system is to be re used plug hoses with screw type plugs with seals, as moisture in the are is detrimental to the system.
Mark (mhpautos)
Dec 30, 2007 at 8:46 AM
