1995 Chevy Lumina 1995 CHEV,LUMINA SUDAN 3.1 LT.
RBLGOBLUE
1995 Chevy Lumina 216000 miles
COOLING FANS WILL NOT TURN ON WHEN ENGINE IS HOT. GUAGE IS PAST HALF WAY POINT.
FAN MOTORS RUNS>TESTED WITH JUMPER WIRE.
RECENTLY REPLACED COOLANT TEMP SENSOR BY THERMOSTAT,AND COOLING FAN RELAYS. RADIATOR HAS BEEN FLUSHED OUT.
IS THERE A SIMPLE FIX TO THIS PROBLEM?
THANKS, RBL
Sep 15, 2008 at 4:09 PM
RENAUDTN
  • 636 POSTS
When you say your car is hot, what do you mean? Overheating?
Can you tell me what is your coolant temperature when you gauge is past the middle?
You can check with an autoscanner what temp your pcm is receiving from your sensor; and when you're at it, check for DTCs too.
Another question: Do your fans come on when you crank up your AC full blast with car idling? (they should within something like 3 minutes)
Now on another note, if your car is not overheating, I don't think it's necessarily abnormal for your gauge to pass the middle without the fans turning on. Some fans don't come on until the temp is 215-220F (thus past the middle on your gauge).
Another thing: don't rely to much on what your gauge is showing; especially in a high mileage car. Your gauge could be off because: it's defective, or your second coolant sensor is bad, or there's something wrong in the wiring. If you want an accurate temp reading, use an infrared thermometer, and check temp at thermostat housing.
Sep 16, 2008 at 10:44 AM
