1994 Chevy Lumina Windows
WEZZYWILL
Electrical problem
1994 Chevy Lumina 6 cyl Two Wheel Drive Automatic
My left side back window just stopped working, again sometimes it will roll up and and down and other days it just wont do nothing what is the problem? Im confused and this is not the first time it happened.
May 4, 2009 at 6:46 AM
JDL
  • 16,098 POSTS
Are you using the switch for the individual window in the back or the master switch in the driver door? Does it make a difference?
If you using the master switch, it could be that switch-- the wiring circuit to the window motor-- motor itself. You need to do some testing.
May 4, 2009 at 7:27 AM
WEZZYWILL
i tried using both buttons the master and the individual and all the other buttons on the master work except that one, and to be honest idk if it makes a difference lol
May 4, 2009 at 7:34 AM
JDL
  • 16,098 POSTS
You can access the circuits on the back of the master switch, see if the circuit is hot when that switch is operated. If it is, you may have to get at the window motor, check the circuit there. Maybe a faulty motor?
May 4, 2009 at 8:06 AM
