1994 Chevy Lumina Turn signal switch
148,000 MILES • 4 CYL • FWD • AUTOMATIC
RACHELLEFLINN
I replaced the fuse for my 4 ways & blinkers. The 4 ways work but the blinkers will blink a few times then stop. Wondering if I need to replace the turn signal switch or if it's something major.
Dec 31, 2009 at 8:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if hazard flashers work then suspect faulty turn signal flasher relay. it is located behind the left side of dash, right of the steering column. it is replaced very similar to how a fuse is...cheap and easy fix.
Dec 31, 2009 at 10:48 AM
