1994 Chevy Lumina trouble codes
1994 CHEVROLET LUMINA
100,000 MILES • 6 CYL • FWD • AUTOMATIC
SMOOTH_THUNDER
Help! I've replaced all 3 coil packs, plugs, wires, fuel filter, catalytic converter & the main computer. I'm still getting codes QDM 1 QDM 4 failure. Also service traction control light is on and can't find any info about what to do about that. I'm over 600.00 in parts & labor and about to drive this thing off a cliff...anyone with a straight answer that is a specialist on 1994 chevy lumina apv!!!
Oct 24, 2008 at 3:14 PM
TEAG
  • 158 POSTS
Quad drivers are basically mini relays built into the PCM/ECM. Each driver controls up to four devices. Either one of the devices is drawing too much current or the PCM/ECM is bad. What was the error code?
Oct 26, 2008 at 9:57 AM
