1994 Chevy Lumina tbi is flooding
1994 CHEVROLET LUMINA
85,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGUN73554
My problem started out small just every once in a while it would try to flood going down the road let up off the accelerator and it would straaighten out. finall got bad so I changed the plugs, filter roter, Distributor cap and checked the wires to no avail. still floods I am used to dworking on the older cars but dont know much about the new ones with TBI Could I get some help out there.
Thanks
Flooding in Oklahoma
Jan 21, 2009 at 5:34 AM
JDL
  • 16,098 POSTS
Hello, can you check for trouble codes? You should be obd1 so you can check them yourself.
If your sure it is flooding, a coolant temp sensor, could cause a problem. I can't say the sensor is faulty, I'm just making suggestions on what to check.
Jan 22, 2009 at 1:02 AM
